i have an advc50 and want to capture some old vhs films , what would be the best way to remove macrovision as i believe the advc50 does not do this ?
thanks
Results 1 to 9 of 9
I here this product is the way to go.
http://www.videoguys.com/sima.htm#sedcm
Should have mine in a couple or days. Got mine off e-bay. I'll let you know if it works.Don't give in to DVD2ONE, that leads to the dark side. -
https://www.videohelp.com/forum/viewtopic.php?t=156944
see the above post, same topic -
The Sima Copymaster is one of the best tools for removing macrovision protection from vhs movies. I used it for about two years until I switched to dvd. I never had a film that was a problem for it. The copies were excellent. If you couldn't compare the original film and the copy side by side you wouldn't know you were watching a copied movie. Best Buy used to sell them for $50. I'm not sure if they still do. Be advised that it doesn't work on most dvds.
The Sima SED-CM Copymaster is the best thing to use for removing macrovion for VHS tape's I have had one for aboutfive year's now you can get them at best buy for $50.00 dollars. It will also work for DVD to Capture card on a PC like ATI AIW or Dazzle or PVR-250. It will not work for DVD to VHS. Sime make's Sima SCC* digital color corrector and copyguard eliminator. This box is junk this one goes go for $100.00 dollars I had two of them and both broke. But the Sima SED-CM Copymaste is a must have
Got my Sima yesterday.
Tested my Aliens tape. Seemed to work fine. I say "seemed" cause, it doesn't seem to work on my "Prisoner of second ave" tape.Don't give in to DVD2ONE, that leads to the dark side. -
Ive had my Sima Copymaster for about several years and it has worked perfectly everytime. It works on my DVD's too without any problems.
VideoTechManI have the staff of power, now it's up to me to use it to its full potential to command my life and be successful. -
Just ordered Sima Copymaster to try with my Sony Giga Pocket machine. If it will make Giga Pocket copy protected VHS I'll be one happy camper. Up til now Giga Pocket has been a biga pain in the ass.
harrymj3 -
Just can't figure it out. Plays fine to the TV. But to the computer I get the blue screen of death.If I FFWD it I can see the picture but as soon as I hit play it's back to blue. Got to be the Macrovision. The only thing I can think off is, the tape must be damaged and the damaged macro is trucking up the works even after my Sima box.
Easycap Video Capture Adapter VHS to DVD Macrovision Removal.
By Teac23 in forum Capturing and VCRReplies: 11Last Post: 23rd Aug 2012, 11:19 -
Converting VHS tapes to DVD, in particular the macrovision issue
By Taildraggin in forum Video ConversionReplies: 1Last Post: 26th Jul 2011, 06:40 -
Best "Black Box" for overriding VHS Macrovision and CopyGuard?
By will7370 in forum Video ConversionReplies: 4Last Post: 20th May 2010, 01:03 -
VHS to DVD (Damn Macrovision)
By ctdvd in forum Capturing and VCRReplies: 15Last Post: 3rd Apr 2010, 19:00 -
What to buy today for Macrovision removal (VHS tapes).
By cowmix in forum Capturing and VCRReplies: 3Last Post: 10th Mar 2010, 16:18
