Hi,
I have some problems with my S520. When I make a copy with DaVideo on DVD and have to split the DVD, the first DVD works but the second one not. When I try the second one on my xbox or my pc or some dvd's (not philips) it also works...
Do anybody know this problem?!
thx for help
bye
Foppa
Hi,
I have a 520 and have experienced similiar issues. (ie DVD works on another player but not the 520)
I think the problem lies in the IFO file on the DVD - and the 520 seems particularly fussy about the navagation and VTS sectors. You can usually fix the problem by running the IFO through IFOEDIT with fix VTS sectors BEFORE you burn.
Cheers,
TeeeRex -
In short yes - I'm not familiar with "DaVideo" - if this software does everything for you and doesn't actually create a set of normal DVD files on your hard disc (ie it creates a disc 'image') then you can't go the IFOEdit route.
However, if it creates a standard set of DVD File (.VOB's with associated .IFO files) then you just need to load IFOEdit, load the appropriate IFO file, click save VTS Sectors, exit IFOEdit.
Then you need to make the DVD image in whatever burner software you use (the IFO should now be correct).
I hope this helps... -
I'll try my luck...
However, I found a DVDxCopy and that programs looks to work better than that Davideo on DVD..
thx anyway..
bye
Foppa
Yamaha DRX-730 HACKS
By math_ferreira in forum DVD & Blu-ray PlayersReplies: 8Last Post: 3rd Jun 2025, 07:44 -
Yamaha DVD-S661
By JCWagener in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Mar 2008, 10:16 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 09:59 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 13:58 -
Yamaha DVD-C950 - Pal-to-NTSC Conversion over HDMI
By Big C in forum DVD & Blu-ray PlayersReplies: 6Last Post: 30th May 2007, 14:18
