does anyone know why when i run besliced to change an ac3 file with a wave header to ac3 it only comes up with a blank notepad and doesnt seem to convert the header?I choose ac3 when ive dropped the file into the box and then the notepad shows up and thats it!!!!any help would be aprecciated
I got the same thing on the CPU that is running XP. So I put the program on a CPU with 2000 professional and just opened it via a network on the XP machine and it worked fine.
Very strange. I wonder if it has some problems with XP.
Hope that helps a little bit. -
Thanks for the help illini19, changed the compatability mode for besliced to windows 2000, and it works.
Glad to help. Still wondering why it has problems with XP.
Oh well, as long as it works.
Funny though, I tried changing compatibility and it still does the same old thing.
I just use my other method I guess. -
Did you change the compatability on the besliced.exe and the besplit.exe as well. I did both, and it seems to work.
Changing default audio in MKV header / Haali issue
By mrg155 in forum Newbie / General discussionsReplies: 0Last Post: 13th Jul 2011, 04:24 -
Changing MJPEG Header Info
By codepenman in forum Newbie / General discussionsReplies: 2Last Post: 14th Feb 2011, 10:42 -
mpg -> AC3 -> mono wave files.
By jocorok in forum Video ConversionReplies: 3Last Post: 24th Jul 2009, 03:15 -
audio levels keep changing, 5.1 ac3-to-wave
By spiritgumm in forum AudioReplies: 0Last Post: 22nd Mar 2008, 10:56 -
Belight settings for correct wave/ac3 volume conversion?
By spiritgumm in forum AudioReplies: 0Last Post: 29th Feb 2008, 13:19
