In the last couple of days I've run into a problem with 2 Criterion DVDs. One had CSS protection and the other did not. Everytime I try to rip the files from the disk, any program I use fails, or, if it did go, I'm left with a VIDEO_TS folder without any VIDEO_TS files. No .ifo,.bup, or .vob. The two disks were Robocop and The Last Temptation Of Christ. Same exact problem. My burner is a Sony DRU120A and never had a problem itself. I usually use DVDdecryptor to rip but I've also used just a window copy (on the one without protection) with the same result. Eventually I had to use DVDshrink and it worked, although I've never liked it's quality. Any suggestions? The error is too weird to be a coincidence.
Thanks.
Try ripping with SmartRipper. Another thing you could do sine you are able to rip the VOB files is use IFOedit to create new IFO's then at least you could use DVD2one or other programs to process the files.
Longevity of Standard DVDs and BluRay DVDs
By bmccollum in forum MediaReplies: 10Last Post: 20th Oct 2010, 19:32 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 02:02 -
Criterion Collection to release BluRay content
By rallynavvie in forum Off topicReplies: 0Last Post: 3rd Aug 2008, 09:02 -
I want software that copies DVDs and transfers torrents to playable DVDs!
By maccaneer in forum MacReplies: 14Last Post: 28th May 2007, 10:02
