I am trying to back a movie and I used DVD Decrypter (in file mode) to extract the entire DVD to disc and then tried to use InstantCopy to remove the extra stuff so that I could fit it on 1 DVD.
But InstantCopy complains about the file being CSS protected. DVD Decrypter said was decryping and showed the key it was using. What does Instant Copy still think it is encrypted?
Thanks!
Results 1 to 19 of 19
Are you sure you are browsing IC7 to the hard drive where you saved the decrypted VIDEO_TS files?
Have you tried playing the ripped VOB files in a MPEG2 player (such as PowerDVD)?
I never had that problem using IC7...
Do u have the same problem with another backup software? If you're not looking for a complete backup (with extras and stuff), you should try DVD2One or DVDShrink, they are MUCH faster than IC7. -
I like IC7 because it remove extra features is super easy and I can preview each VOB before I delete it and IC7 deletes all related files cleanly.
I don't want to lose quality so I have stayed away from DVD2One and DVD2Shrink. -
Also be careful that you're not holding one of the files open with another application like Media Player or IfoEdit - IC7 generically complains about CSS encryption if it can't read a file for whatever reason.
I prefer DVDShrink's quality to IC7's quality, but I guess it's up to everyone to choose the method they prefer.
Originally Posted by Will Bailey
what quality?
from that statement I presume you are a movie-only fan?
what about the big boys like Saving Private Ryan, Gladiator, Pearl Harbour, Titanic etc?
do you honestly prefer DVDShrink to IC when you are talking about quality?
but then again, as you said, everyone is entitled to their choice
but in other issues the quality opinion disagreement regarding all backup tools is always due to the user's quality standards and the quality of image displayed by the setup used and you can have quite a few combinations so you will get a few disagreements
but as of yet no-one I know of no-one that has proven that DVDShrink produces better quality than IC, yet IC has been proven countless times to be better quality than DVD2One/DVD95Copy/DVDShrink and I believe those posts are also backed up with evidence rather than just comments
even I have posted obvious quality comparisions but some people still claim not to see differences and this is a perfect example of the range of different quality images that are produced by user's setups even using the same picture!
since you are stating you prefer the quality and you are not saying that it is better, I apologise if any offence is taken but I am talking to everyone not just yourself
No actually I am a full disk fan. I don't understand why you react this way. It's just a personal opinion, I'm not saying DVDSh is better for every movie and for everyone. I am just talking from my personal experience.Originally Posted by MackemX
Yes, I do prefer DVDSh to IC, when I'm talking about quality. My player produces a clearer picture for DVDSh backups, but this is just my opinion. Plus, IC is slow as hell; if in 30 min. I can get a better or equal quality, I'm going to use DVDSh.
I think you checked my topic with the tests I've made using different progs. I said I think there is no ultimate backup software and once again, it's just my opinion. I actually use IC in the end because extras are more compatible when I play the backups in my DVD player. I have issues with extras when I use D2O and DVDSh. (on 3 different movies, as for now).
Btw, I do not want to prove anything but just share my experience with other users. I'm glad you stated at the end of your post that it wasn't aimed at me, because I just want to help other users, that's all. -
I gave him my advice just above. If he wants to keep trying with IC7, it would be interesting to know which movie he tries to backup (region, etc)and maybe some users encountered the same problem with that movie in particular.
Are you using the very last version of IC7? -
stuff has been suggested for robinmthomas to try, so what's wrong with discussion till he replies whether he has had failure or success?Originally Posted by K2
I have 101 questions I could ask but I have pointed him to the basics 1st by telling him to check his settings
If they don't work then I will advise something else
Thanks for all the replies.
Other movies work fine using this method. I haven't backed up many movies, but this is the only 1 out of 10 I have done.
My settings are identical to the page that you linked to.
WinDVD can play the VOB files with no problem.
Is there a way I can tell if this is a DVD Decrypter or a IC7?
i.e. Can I tell definately if the copy protection is actually removed?
Also, could this be an anti-copy method or just a fluke?
The version of IC7 I am using is 7.0.1 -
I think VidGuy gets the points, I verified that IC/DVD Decrypter wasn't running, but after a reboot it worked. So I am guessing that some thread was still locking the file and IC couldn't access it.
However, the weirdness doesn't stop, the movie appears to have 2 copies of Wide Screen (the case says it is just widescreen) and if I uncheck one of the movies, IC automatically unchecks the other as though they are part of a set.
Why these two exact (same length, aspect ratio, etc) copies of the movies be linked? And can I unlink them?
Thanks! -
it's because the two PGC's (Titles) will both refer to the same VOB ID's at some point or other
so if you remove one Title it will affect the other Title, so therefore they are linked
as to how much the Titles are interlinked you can check using IfoEdit
are you comfortable on how to do this? -
Nope, I am brand new to this. I just got my DVD burner last week.
Maybe InstantCopy was the wrong choice, but it seemed like the only choice that the focus was on not reducing quality but reducing content (i.e. leaving widescreen and skipping full screen).
I also liked the IC7 was a 2 step process with little manual intervention.
1 - Rip from DVD Decrypter and walk away for 30 min.
2 - Load into IC7, spend 5 minutes removing titles, and burn to DVD and walk away.
Is there a better tool which has the focus on quality and isn't terribly manual?
I can handle complicated -- I used to rip to Divx back when it took 15 steps and 15 different programs....
Thanks!
Should non Standard Copy Protected DVDs use the "DVD Video Logo?
By TubeBar in forum Newbie / General discussionsReplies: 10Last Post: 23rd Sep 2013, 18:20 -
Getting "Fair Use" copy of last "Byrds of Paradise" episode
By Ronald Vaughan in forum Newbie / General discussionsReplies: 4Last Post: 14th Jul 2010, 22:09 -
Can I bypass "copy blocker" to copy from VHS to DVD
By jgloeckner in forum Newbie / General discussionsReplies: 10Last Post: 23rd Nov 2008, 00:40 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 01:31 -
How to copy/convert hidden DVD with only "Track01.cda" in dir
By vincehal in forum Newbie / General discussionsReplies: 9Last Post: 8th Nov 2007, 07:21
