I have a Pinnacle PCTV Tuner Card. The software is ehh ok, was wondering if i used different software would i get better results with video capture's. If so, some suggestion would helpthx
Hello there . . .
I use something called VirtualVCR (from www.digtv.ws) for all my VHS and TV captures. I normally capture at PAL SVCD resolution (480 x 576) and then filter etc using VirtualDub before encoding with TMPGEnc or CCE 2.5.
Over the length of a 2.5hr capture I might be dropping 1-5 frames - more than happy with that!! Overall, VirtualVCR is an excellent little program and highly recommended.
Cheers,
B.===============================
"Don't ask for my specs - click the b*&^dy button . . ."
darkcrow7,
Try Virtualdub ( http://www.virtualdub.org ) !!!! In my opinion the BEST capture program available and the best thing.... ITS FREE !!!!
Also with Virtualdub it is possisble to tweak things, so capturing with different resoltions, capture to all kinds of codecs (eg. DivX (need fast processor, though)), etc...
Did some capturing: CPU util 20-30%, frames lost : 0!!!!!
'HAG
An LCD TV without 75 ohm coax input install where only a coax input can be
By dss4u in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 13:09 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 12:46 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 09:59 -
One input record other input?
By Davron in forum Capturing and VCRReplies: 1Last Post: 30th Jan 2008, 18:20 -
FFMPEG and input A/R
By nic2k4 in forum Video ConversionReplies: 1Last Post: 14th Nov 2007, 20:39
thx
