I have read the various guides and forums on this but still cannot get tmpgenc to accept the vdr file.Tried renaming file xxx.vdr.avi/xxx.avi.vdr nothing.Copied file msvcr70.dll to sysems32 dir,nothing.Tried aviproxy on/off,nothing.Avi handler is installed.Vfapi settings in Tmpgenc has directshow with a priority of 2.What am I doing wrong??Open file in virtualdub make my changes resizing,framerate.Start frameserving,hit start,name file.Then I try to open the new vdr file in tmpgenc get the error unsupported.Settings in virualdub no audio,video- resizing,framerate conversion,no compression.Tried virualdub 1.5,1.4mpeg,1.4c ac3,1.45.Any suggestions would love to learn how to use this option would save alot of time and space instead of making another avi file.Thx for any help and / or guidance.
in tmpgenc, make the AVI2(opendml) vfapi plugin on the top of the priority list. If this doesn't work, try looking for a vfapi plugin called readavs.dll (on google.com). Its designed for reading avisynth scripts and virtualdub frameserver signpost files.
edit: here's a link for the readavs.dll plugin.. be sure to change the .reg file to reflect where you place this dll
http://shelob.mordor.net/dgraft/www.math.berkeley.edu/benrg/avisynth/tmpgenc-readavs.zip -
Works like a charm!!!!!!
THX liquid 217
Don't forget to name your new file in virtualdub to xxx.vdr then open in tmpgenc -
I just tried everything mentioned in these posts but still i cant' get the vdr to load in tmpgenc!! ahhh this sucks...and just 2 days ago they were loading perfectly but now for some reason I can't load any vdr files in tmpgenc. please help
tahnks
Virtualdub kernel32 error, TMPGEnc cutting video
By koberulz in forum Newbie / General discussionsReplies: 5Last Post: 11th Apr 2012, 12:36 -
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 10:24 -
TMPGEnc Plus 2.5 saying unsupported??
By Suprman37 in forum Video ConversionReplies: 10Last Post: 12th Oct 2007, 18:51 -
AutoGK Error - Unsupported audio type
By bjblackmore in forum DVD RippingReplies: 7Last Post: 13th Jun 2007, 20:19
