Is it possible to convert a .ogm file to a SVCD using ffmpeg? If this is possible what do you need to do to make it work...?
Thanks in advance for any suggestions,
cashew
Have not done much with .ogm files
heres some info on them http://ld-anime.faireal.net/guide/ogm-en
im sure you can hunt around for some more.
I would try opening the .og file with video lan to see if it will even play!
if not, i bet you will have to wait some until that file is supported more in OSX.
Conversion may be possbile, depending on if it will actually PLAY!
try that first and post your results.
If it does play, try renaming it to .avi and running it through ffmpegx for SVCD standard settings, and see what you get.
Id wager to say your in experimental territory here.
OGM is supported in VLC 100% --- even multiple audio and subtitle streams.
However, the conversion is still lacking heavily at this time... I would imagine that if demand increases, so will development.
The Matroska format is looking pretty juicy right now, and I have a feeling that once it is usable, it will put an end to .OGM and .AVI containers. -
Matroska?
Q"Good Luck 007"
In Memory of Desmond Llewelyn -
i have no problems viewing the file. I want to re-encode the file to SVCD. Basically it's been beyond frustrating trying to do this. It's impossible to do on a Mac...! Which I've come to realize.
So I threw in the towel, and used a PC
. Even then it's a bitch too do!
Whoever came up with this god-for-saken format deserves to be shot!
Agreed! It is a Great idea though... It is perfect for multilanguage movies and people interested in subtitle streams. It will be no problem converting the .ogm format to ANY other format once it supported in Mplayer.Originally Posted by cashew
Im just waiting for matroska.
www.matroska.org
Working with MKV files?
By terrypin in forum Newbie / General discussionsReplies: 8Last Post: 9th Mar 2012, 08:14 -
Converting OGM files to AVI/MPEG with subtitles
By StevoK in forum Video ConversionReplies: 1Last Post: 4th Feb 2010, 01:50 -
ogm file with subtitles isnt working
By dudeboy in forum MacReplies: 0Last Post: 5th Sep 2009, 07:53 -
Working with MP4 files?
By terrypin in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2009, 07:10 -
OGM files with internal subs that won't display.
By bizzybody in forum SubtitleReplies: 0Last Post: 13th Jun 2009, 12:40
