I'VE BEEN TRYING TO CONVERT AVI TO MPEG FOR VCDS AND KEEP GETTING "ERROR READ CODE AT ADDRESS 00401C9D IN MODULE 'TMPENC BACKUP.EXE' REFERENCING ADDRESS FFFFFFFF" AS WELL AS "THE RUNTIME ERROR 216 AT 00002F26" BOX. THESE ARE NOT ALWAYS THE SAME IE "0047D343 AND 07112B30", THIS WAS DONE AT 95% COMPLETE.
IS THERE SOMETHING I'M DOING WRONG? I'VE FOLLOWE DTHE INSTRUCTIONS FROM THIS SITE USING 12A RELEASE WITH DIFFERENT MOVIES.
CAN ANYONE GIVE ME A TRUSTED DOWNLOAD SITE THAT WORKS IF THIS IS THE PROBLEM?
AM I MISSING SOMEHTING SIMPLE OR IS THE PROGRAM IN SOME WAY CORRUPT?
I'VE TRIED IT SO MANY TIMES I'M GOING INSANE!!!
HELP!!!
Well for one, upgrade to at least 12H.
2nd, if that doesnt work, i am assuming you are running WinME and WinME has problems -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I'M RUNNING 98 R2, BUT WILL TRY UPGRADING TO A HIGHER RELEASE OF TMPENC
TMPGEnc Authoring works 4 - Access is Denied (Error code 0x80070005)
By The Roo in forum Newbie / General discussionsReplies: 3Last Post: 17th Mar 2021, 18:34 -
Error: The source image format is not acceptable (error code -2)
By Russo in forum DVD RippingReplies: 3Last Post: 5th Jul 2011, 11:50 -
Registration Code Error
By ghillman100 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Apr 2011, 11:07 -
Error: Sense key=Medium Error. Sense Code=0x73, 0x03.
By Idlewild in forum MacReplies: 14Last Post: 10th Mar 2008, 12:36 -
TMPGenc DVD Author 3 issues "No stream available" Error Code 0x80
By newsletters in forum Video ConversionReplies: 0Last Post: 8th Oct 2007, 18:20
