Hey guys,
I have:
Leadtek WinFast TV 2000XP Deluxe
Pentium III 800
Geforece4 Ti4200 64MB
384MB PC-133
Windows XP Pro
and im having some problems. I can't capture at 720x480 or even at 640x480 without it being choppy. does anyone have any suggestions for this?
someone was telling me that i might have to get better quality and name brand ram...can someone confirm that?
the likelihood is the processor is too slow. try a lower resolution, should help although may still be choppy
buddyboy, you need to enter the world of the gigahertz [GHz] processor to get the fantastic results that this card can offer including 720 x 480 NTSC capture.
I have this card and quite pleased with same but run it on a Gigabyte GA-7VAXP motherboard with an AMD 2400+ processor and 512MB DDR RAM.
do the upgrade or test in a 'stronger' machine and you'll see. -
You need to capture using avi w/huffey codec. Your computer isn't powerful enough to capture mpeg sucesfully. Also set your PVR on channel 3 or 4 and use your VCR as the tuner, much cleaner results.
harrymj3 -
Well,I have a similar spec Celeron 900 to a 2nd capture 40Gb ATA 100 7200rpm HDD & equipped with a PCTV pro (Windows 98 1st Ed), & managed several VHS to VCD conversions successfully with these "lowly specs"!! It just requires a little more patience & time.Originally Posted by wecc
As harrymj3 mentioned, I can capture to 640x480 25fps PAL using Huffy AVI to the capture drive & soft-encode to VCD mpeg 1 352x288 using VirtualDub frameserving to TMPGenc. Look for a program called "End it All" which'll kill any unnecessary background tasks,(disable AntiVirus s/w etc. too), & any preview type windows can all help gain speed.
In my case though having the VCR/TV next to the PC means I can work out when I need to stop/start VirtualDub or AVI_IO capturing at the right times. (hence switching off overlay/preview modes)
Leadtek Winfast TV2000XP Expert problem with sound
By roc383 in forum Capturing and VCRReplies: 22Last Post: 1st Dec 2010, 12:32 -
Does the SpursEngine devices, IE Leadtek's WinFast PxVC1100 work good?
By TBoneit in forum Video ConversionReplies: 3Last Post: 15th Aug 2009, 17:50 -
Leadtek Winfast pvr2000 (retail)
By fulgur in forum Capturing and VCRReplies: 7Last Post: 4th Nov 2007, 10:05 -
Help: No sound at all with a Winfast TV2000 XP Deluxe
By Deathwish238 in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2007, 13:01 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 14:22
