I just bought a Matsui V-DVD500 DVD/Video combination costing me £175
I go to try various discs and get the following results...
VCD/SVCD = Error Please Check Disc
MP3 Disc = Error Please Check Disc
*Copied DVD* (I bought this of someone, i don't know what sort of rip it is) = PLAYS FINE!
Now this is a bit annoying if this can't play vcds becasue i don't have a dvd-rw so i can only burn vcds.
The specifications of it are...
Colour System - PAL
Disc - DVD, CD-DA, CD-R/RW
Disc diameter - 120mm, 80mm
Pick up - 1-Lens 2 Beams System
I'm hoping it should be able to read vcds as it says CD-R/RW, or should it say VCD if they were supported.
And what is a CD-DA, thanks
search the DVD player section for the maker of your DVD.
It's no use getting mad.
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 17:32 -
New LG DVD Player not playing VCDs
By atlmallu in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Dec 2010, 16:28 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55 -
Insignia portable DVD player can't play VCDs
By Amuse in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Nov 2007, 20:28 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 12:46
