I have been making backups for a while now using DVD2ONE Record now Max and my Pioneer AO4 without a hitch. I usually use either DVD-Pro or Accu Discs. Now all of a sudden with I burn the Video TS folder that DVD2ONE makes using Record Now Max it won't play in the stand alones I usually play it in. Although it will play in a DVD player I own that never plays DVD-R's. Anyway if I use IC7 it plays fine. If I use NeoDVDplus its kind of hit and miss sometimes it works sometimes it doesn't. I can't use Nero because for whatever reason about halfway through the disc it comes up with a communication error and stops. My question is why all of a sudden am I having these problems? I can't think of anything that has changed in my system that would cause this.
I can think of no reason for this behavior. Is DVD2ONE the latest version?
"some days just suck"
Good luck
What did you do for father's day?
By johns0 in forum PollsReplies: 7Last Post: 21st Jun 2010, 00:20 -
How much sleep do you need each day?
By Baldrick in forum PollsReplies: 26Last Post: 15th Dec 2009, 00:46 -
DVD playback fine on computers, but not so fine on home players...
By stonesfan in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 17:03 -
M2TS fine, MKV not so fine.
By sixleaf in forum Blu-ray RippingReplies: 6Last Post: 26th May 2009, 02:35 -
Will this day ever end?
By pantsonfire in forum Off topicReplies: 11Last Post: 19th Oct 2007, 13:52
