Hi, I recorded some movies from cable on the panasonic dmr-e50 settop recorder to dvd-r...
I want to make a copy of that disk with my panasonic 521 dvd burner(pc)...what are some good software titles that will make a perfect copy of the movie dvd-r's I record from the tv,, or any dvd-r's that I make, that are not copy protected, macrovisioned or anything...i.e. also I put vhs tapes I recorded via camcorder of my daughter up and encode to mpg2 and made a moviedvd of them...how do I back them up? what softwares are good for that?
I tried veritas recordnow...it did ok, but had a couple read errors....and the movie was ok except at the end where the errors were and it was choppy...
Again these are not movies with copy protections, but dvd's I burned at home. The disk to disk in recordnow is mainly for data disks and computer progs right? thanks...t
using disk to disk should be ok but you could also use dvd decrypter to make an iso then burn it back again.
thingimijig. -
I've used RecordNow DX to make D2D copies of my Backup DVDs with good success.
LTA -
Yeah but DVD Decrypter is freeware
1) Run DVD Decrypter, choose "mode | iso read"
2) Make copy an image on the DVD/R disc to your HD
3) Choose "mode | iso write", select the image file and burn
There are guides (with pictures) of this process if you click to the left under DVD Rip. -
I agree with "thingimijig"
Use DVD decryptor in ISO mode. (quick and easy)
If it has read errors then you have a problem with your source DVDs.
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Converting 2-Disk Sets to 1 Disk
By 1337assassin in forum Newbie / General discussionsReplies: 18Last Post: 23rd Oct 2010, 09:53 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
Copying Multiple VIDEOS onto ONE DISK.
By UmmAddan in forum Newbie / General discussionsReplies: 3Last Post: 30th Dec 2007, 18:30
