I am going to buy a new computer. It will be used for video editing, conversion, and authoring 1-3 times a week. I hope it will be reasonably speedy. Anybody can give me some advice on the memory and video card?
Does video editing, conversion, and authoring use mainly memory or video card?
e.g. 512M memory with 32M video card, or
256M memory with 64M video card?
In addition, what are the other hardware or software I should consider?
Thanks in advance!
It mainly depends on the processor, not the video card or the memory. 256MB should be fine, 512MB is better if you intend to do editing. The video card hardly matters. A really bad card will hurt you, but a really good one won't help you that much.
Blue ray and Videocard compatibility
By alc112 in forum Newbie / General discussionsReplies: 4Last Post: 10th Feb 2010, 14:24 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 06:16 -
videocard
By hendriekoek in forum ComputerReplies: 1Last Post: 18th Sep 2009, 12:21 -
videocard for editing HD, Nvidia Quadro FX 570 ?
By hendriekoek in forum EditingReplies: 0Last Post: 18th Sep 2009, 05:15 -
Adding a videocard to my PC
By avz10 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 16th Mar 2009, 14:22
