I'm not sure if this is the right forum for this question, but I'll try it. I have a nVidia GeForce 2 MX 400 card w/ tv out on my computer, connected to my vcr, which is connected to my tv. My tv doesn't have composite inputs, that's why I'm using the vcr. My monitor is 17", tv is 27", so I want to watch my dvd's on the tv, but the dvd's have some protection, so I cannot project it like i want. Is there anything I can do, programs or hardware, besides converting the dvds to vcds. All my vcds work fine.
You need a software tool either DVDIDLE or TVTOOL to bypass the copy protection. Usually if you connect the tv-out to the tv directly or to a very old vcr it's ok and you don't need to bypass anything.
Those 2 progs have trial versions.There's not much to do but then I can't do much anyway. -
If your TV doesn't have any cxomposite inputs, but it does have a scart input (well, most tv's do, don't they?) then you'd better get one of those scart/composite thingies. http://www.diskidee.nl/images/s/svs_pc_op_tv_foto3.jpg
Just because you aren't paranoid, doesn't mean they aren't out to get you!
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
VHS to DVD+R playback on computer
By rchunah in forum Capturing and VCRReplies: 3Last Post: 9th Sep 2009, 11:37 -
how to 'upscale' dvd playback on a computer
By slimselecta in forum Newbie / General discussionsReplies: 7Last Post: 28th Feb 2008, 16:03 -
SONY Burnt DVD+R's Work Fine in Stand-Alone, But Won't Playback in Computer
By MYSTiCKWARLOCK in forum MediaReplies: 3Last Post: 13th Nov 2007, 03:27 -
DVD recorder -> playback on computer
By blazejay in forum DVD & Blu-ray RecordersReplies: 2Last Post: 20th Sep 2007, 13:22
