Can someone let me know what the max resolution supported for this card is. I want to use it in VirtualDub and would like to capture avi's at 640x480 then convert to svcd with Tmpgenc. I tried searching this forum, but didn't see anyone list this. I know it does 720x480, but I beleive that is Mpeg2 format captures. I checked Ati's webiste, they list nothing. But for the Fury Pro 128, supposedly same card, no tuner, they say 640x480 for avi's. All other AIW cards list 320x240 max on Ati's site.
<font size=-1>[ This Message was edited by: psycaz on 2001-09-18 13:18:42 ]</font>
I have the AIW 128 Pro, and I know that I can capture
MPEG-2 & 1 at 640x480, but I don't do much with AVI.
I'm sure it does. (I'm at work now so I can't check)
Hope that helps. -
I did find that info - that you can capture to mpeg1 and 2 at those formats. If you (or anyone) could let me know what they get for avi's, I'd be greatly appreciative.
<font size=-1>[ This Message was edited by: psycaz on 2001-09-18 19:00:09 ]</font> -
It is possible to capture AVI's @ 720x480. I have done it w/V-Dub. My computer is slow(700mhz) so I drop a lot of frames but it does work.
Thanks,
I am building a new Athlon 1.4 system and need to get a new vid card - I will get this one since I can get it from Best Buy for $99 after rebate.
<font size=-1>[ This Message was edited by: psycaz on 2001-09-18 20:34:46 ]</font>
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 18th May 2010, 23:35 -
VideoStudio X2 Pro max bit rate?
By Mike82 in forum Authoring (Blu-ray)Replies: 1Last Post: 26th May 2009, 22:56 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 20:53 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 15:36 -
Didn't ATI All in Wonder 128 Pro have Mpeg capture?
By Ensign in forum Capturing and VCRReplies: 7Last Post: 7th Mar 2008, 09:13
