has anyone got one of these players from ccl as its seems v cheap to me
http://security.cclcomputers.co.uk/acatalog/
does it produce +r dvd that will play in most standalones
ps the one at 110 quid plus vat i mean
Results 1 to 11 of 11
http://prices.cclcomputers.co.uk/specs/cdrom/NEC/1100AOEM/spec.htm
oops better link -
Stay away from this drive. I had the NEC1100A for about 2-3 weeks and I must say that it's THE WORST piece of hardware i've EVER had. Horrible quality, destroyed many DVD+RW disk that could not be read, erased, or anything. Even after the firmware upgrade, it still was horrible. DO NOT BUY IT!!!!!!!!!!!!!
ive had 1000a and never had a problemOriginally Posted by binks120
there well worth the money
It was only the Dell version that had problems with rewriting DVD+RW media and you seem to be the only person for which the new firmware hasn't fixed this problem.Originally Posted by orbital517
The retail/bulk version has never had any of these problems nor have the OEM drives that are based on the NEC like TDK 420N, Plextor PX-504A or HP dvd300.
BTW quite fun to see you writing "stay away from NEC ND-1100" in this thread when you recommend the TDK 420N in another thread (basically the same drive)...
I have the NEC ND-1100A (bulk version) myself and it has worked perfect. The ND-1300A (supporting both + and -) should however be out very soon now (and rebadged versions of this like TDK 440N) so it might be worth waiting for this. -
I have three burners and one is the NEC 1100a which works just fine at 4x. Never had a bad burn with the twenty or so Verbatim discs I have burned at 4x.
cheers dudes i got it today couldnt not at the money
as for -r disc support who needs it the discs will soon be more expensive and they are not as friendly with standalones -
I just got this dvd writer and would like to know what dvd+r and dvd+rw media works on this unit? Thanks
Just got this drive not too long ago, have yet to have any problems and has worked with every type of DVD and CD I tried.
DVD+R
Philip, Memorex, Verbatim
DVD+RW
DVD-on
CD
JUst about anything you can think of including Sony, Imation, Verbatim, TDK, Memorex.
The DELL NEC drives had issues, but all the people I have talked to that purchased this drive seperate have had good luck with it. -
I bought an NEC 1000A 2.4x DVD+r re-writer and flashed the firmware to make it an NEC 1100A 4x re-writer (see http://forum.firmware-flash.com/viewtopic.php?t=14416&highlight=nec+1000a for instructions as to how it can be done).
Bought the 1000A for £90 inc. VAT.
Bargin or what ?Cheers,
Jeepster39 -
I have a ND-1100a and i am more than happy, the discs have worked in everything i have tried them in.
cheap portable speakers.
By meneedit in forum Off topicReplies: 0Last Post: 9th Mar 2011, 04:25 -
Looking for a cheap shotgun mic
By 872156 in forum AudioReplies: 8Last Post: 13th Jul 2009, 22:25 -
daewoo dv-1100a region free hack
By noblegirl in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Jun 2009, 19:18 -
I can get this cheap. Questions on what I can do with it.
By GLE3 in forum Capturing and VCRReplies: 16Last Post: 16th Apr 2009, 21:40
