I normally cut MPEGs (muxed) with TMPGenc. I'm trying to back up a DVD I own, and have a CCE encoded m2v file + ac3 file. But I did the bit rate wrong and need to shrink the m2v by 10-15MB.
I want to cut out the closing credits, I tried cutting w/ TMPGenc. But DVD Maestro can't read the edited file. What program (and/or setting) do you suggest for cutting just m2v video files? Thanks in advance.
Thanks I'll give it a try tonight. I just don't want to have to re-encode the entire project to cut the size by 10-15MB
I guess worst case I can convert the ac3 audio to mp2, mux to get a MPEG2 file, cut with TMPGenc, demux then use the orginal ac3 file as audio source. -
[quote]
I think this might be your best bet trustme been there!!!
crop m2v video file
By robbtek in forum Video ConversionReplies: 3Last Post: 17th Feb 2011, 11:58 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 07:17 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 21:25 -
How to reverse a M2V file
By lorix in forum EditingReplies: 2Last Post: 13th Nov 2008, 05:09 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08
