Does DTOX do any transcoding if the movie will already fit on a DVD-R? Or does it just assemble the VIDEO_TS folder correctly? Thanks.
DTOX doesn't perform any significant compression if the files are small enough to fit on a 4.7 GB disk.
There have been several instances where I've used DTOX to extract just the movie from a disk filled with extras and where those files are less than disk-size. I used to use OSEX to strip out the elementary streams and rebuild in DVDSP, but I find that DTOX is a lot faster/easier.
Some early comparisons showed that the file sizes were close enough that there was essentially no compression going on. -
if the whole disc is under 4.7 , you would just use dvdbackup or osex. there is no need to go to dtox. but if the movie you want is under 4.7, like the animal, spy kids 2, or once a thief, it does no compression and just takes that movie and makes the dvd.
pants on, pants off, pants the floor. -
Using DTOX is a lot easier (as stated) than rebuilding chapters and whathaveyou in Sizzle or something.
But if you are wanting to backup the movie. Simply use DVDBackup to extract teh VIDEO_TS folder, then reauthor the folder to a DVD. No compression, and the DVD you burn will be exactly the same as the original. Chapter points, menus, extras, everything. BUt only for movies under 4.4GB.
The movie (Sum of All Fears) would be under 4.4 if I don't include the 4 languages and all the subtitles. That's why I need to run it through something (OSeX-Sizzle or DVDBackup-DTOX).
How to make video files much smaller?
By crossword in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2009, 08:30 -
How to make vob files smaller
By aruwin in forum Video ConversionReplies: 2Last Post: 26th Jul 2008, 15:25 -
Dividing an AVI into smaller files
By hygieneboy in forum EditingReplies: 15Last Post: 25th Apr 2008, 16:31 -
Smaller Video Files
By Dj-Viper in forum Newbie / General discussionsReplies: 1Last Post: 25th Mar 2008, 10:31 -
Smaller MPEG-2 Files?
By DigitalSounds in forum Video ConversionReplies: 12Last Post: 30th Oct 2007, 03:55
