Is there any particular software that can bypass the copyright codes? Does DVD X Copy offer this?
I take it you mean copying a dvd to your computer. If this your question then the answer is yes there are numerous applications that offer this functionality. Two of the most popular being dvd decrypter and smartripper
what i really want to do is make a backup of an existing DVD I have. And if it is copyright protected, will these applications allow me to successfully burn them?
Follow any of these guides - https://www.videohelp.com/dvdripping
You will have several steps depending which method you choose.
ie.
Rip
Burn
or
Rip
Encode
Author
Burn
You should try to look through the site (especially the guides) before you ask~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
The best DVD burning software
By tarzan54 in forum DVD RippingReplies: 22Last Post: 1st May 2012, 06:11 -
By ingeborgdot in forum DVD RippingReplies: 6Last Post: 17th Sep 2011, 15:10 -
Anyone here use Burn4Free burning software for DVD?
By snafubaby in forum Authoring (DVD)Replies: 2Last Post: 22nd Feb 2009, 20:24 -
Looking for DVD Burning Software!
By mats.hogberg in forum DVD RippingReplies: 1Last Post: 29th Nov 2007, 10:52 -
Best DVD Burning Software for flagging 16:9?
By markannab in forum Authoring (DVD)Replies: 17Last Post: 4th Jun 2007, 14:09
