  1. ok i am having a huge program
    very big i think
    well i can get my tv anywhere card from msi to work
    with the MSIPVS software but not with nothing else.
    I tried Intervideo Recorder Nothing it wont work even though i seletcted the right capture device.. then i tried POwerVCR again just a big blue screen with the right capture device
    I need some HELP
    Please
  2. Do a search for your Cap card in the MSI forums.
    http://www.msi.com.tw/program/e_service/forum/main.php
  3. I've got the same card. You don't like the software? Other than the fact it doesn't cap over 4 gigs, I like it.
    Don't give in to DVD2ONE, that leads to the dark side.
  4. Got this off the forum.
    I had problems with the file split size as well but got around it by hacking the registry. If you go to HKEY_LOCAL_MACHINE/SOFTWARE/INTERVIDEO/WINDVR/FILE , you will see the file split size is set to 4GB. I changed it to the file size I wanted and it worked. The downside to this is every time you switch profiles, you have to change it in the registry.
    Don't know if it works.
  5. hmm... didn't work for me.
  6. I opened this file with Notepad "Record Profile".
    At this location
    "C:\Documents and Settings\All Users\Application Data\InterVideo\WinDVR"
    When you open it you get this.
    [PROF_0]
    ProfName=VHS to DVD
    ProfId=2003414105649406
    ProfComments=
    ProfLocked=0
    TotlaBitrate=10107
    CaptureFormat=0
    VideoWidth=352
    VideoHeight=480
    VideoFrameRate=4
    VideoAspectRatio=2
    VideoFormat=2
    VideoMPEG2=1
    VideoBitRateMode=1
    VideoBitRate=9500
    VideoPeakBitRate=9570
    VideoVbvBufferSize=112
    VideoGOPSize=3
    VideoSubGOPSize=3
    VideoMotionVectorH=0
    VideoMotionVectorV=0
    VideoSeqHdr=1
    MPEGAudioSystemLayer=2
    MPEGAudioBitRate=224
    MPEGAudioSamplingFreq=48000
    MPEGAudioSystemMode=0
    MPEGAudioQuality=75
    MPEGAudioRealtimeEncode=0
    MuxPackSize=2048
    MuxPacketsPerPack=1
    MuxAddPadPacket=1
    MuxFixedPack=1
    MuxMpeg2Mode=1
    MuxRealtimeEncode=1
    FileBoundary=14398045462528
    DnScScaleDown=3
    [PROF_MGR]
    PROF_NUM=1
    SEL_PROF_ID=2003414105649406
    If I change the FileBoundary #, that works. As long as you don't edit it again in the MSI program, otherwise you will have to do it over again.
