Hi all, is there a conversion tool out there that I can use to convert a couple of mpeg files for use on the web - that means I think that I should be converting to wmv. Am I right in thinking that wmv are simply compressed mpegs??
Wmv means Windows Media Video, and this is its own codec (type of video encoding format).
Microsoft offers a free program, Windows Media Encoder, for encoding into this format. It is a rather elaborate program with a lot of options. I cannot remember off-hand if it accepts mpeg files directly. You may have to convert them to uncompressed AVI first.
For "use on the web," do you mean produce streaming video, or do you simply want highly compressed files for sharing. If it is the later, then there are other video encoding options. If you want to produce streaming video, then yes you should take the time to mess around with Windows Media Encoder. -
In addition to WME, if you are running XP you can download MovieMaker 2 for free which will convert mpgs to wmv in a variety of profiles via a wizard. It is also faster, in my experience, than the February version of WME 9. WME9 sucked in the speed category in doom9 's latest, definitive codec comparison http://www.doom9.org/codecs-103-1.htm#setup It faired well in other categories.
Good Luck!
Getting two fatal errors when extracting mpgs from vobs
By Antony in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 15th Apr 2012, 01:24 -
Making mutilple MPGs from Avi Files
By funkymix in forum ffmpegX general discussionReplies: 2Last Post: 16th Mar 2009, 23:37 -
Join several mpgs together
By milway in forum Video ConversionReplies: 2Last Post: 13th Jul 2008, 21:49 -
How to convert wmv clip so its properties match other wmv clips
By sohaibrazzaq in forum Video ConversionReplies: 4Last Post: 4th Aug 2007, 10:16 -
Quick Question re: Joining mpgs
By boing in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2007, 14:35
