Hello i was wondering if anyone is using this card.
i just installed it
and for some reason it only has MONO sound i did all the updates etc from the msi web site
does it actually do stereo sound? i see it in the options but it's greyed out.
anyone know?
thanks in advanced
Assuming you're in the USA....
Some say it's a driver issue and others say it is a hardware problem. When you look at the product brief from Conexant's webpage, it says that the CX23880 (@nywhere's chip) should be able to work in Stereo. MSI definately includes a stereo audio cable in the box, so who knows? Unfortunately, I have read no posts of anyone being able to get Stereo to work for a US television system.
This chip is still in its infancy and if this is a bug in the driver it will eventually be corrected, but it may take a while. If Conexant says the chipset can do it, I have to believe them until proven otherwise.
Another card based on the same chipset is the "Asus TV Tuner" card. The Prolink XCapture uses the CX23881 (european chipset?) on their American card. You might want to see if you can find users of these cards and see if they are having the same type of problems.
BG -
Not sure about posting links. If I'm not supposed to, I apologise, and hopefully the mods will delete it.
Try the MSI forums here
http://www.msi.com.tw/program/e_service/forum/main.php
There's a quite a bit about it. -
When I first installed the software it was mono, even with the updates. After the reinstall with the updates it's stereo....?
Don't give in to DVD2ONE, that leads to the dark side.
Msi/asus/dell editing laptop?
By amigo-productions in forum ComputerReplies: 11Last Post: 6th Dec 2011, 02:45 -
msi motherboard replacement
By mixxerr in forum ComputerReplies: 10Last Post: 21st Aug 2008, 01:09 -
recommendations for motherboard ASUS or MSI?, dual amd 64 ?
By poolenglish in forum ComputerReplies: 3Last Post: 8th Jun 2007, 17:05
