I have downloaded this divx movie. Everything is perfect except it has subtitles (translation of what has been said in the movie) in German language at the bottom of the screen in every frame in the movie. I can understand the movie because it is in english but i just find this extra writings at the bottom very annoying. For me there is no use for it. therefore is it possible to get rid off the subtitles in the movie so it would look like as its original release? please help and thanks![]()
hi,
I believe DVD2One is for DVD conversion only....
If the DivX movie exists only of a .avi file and not extra files for the subs, you can't just remove them. There are hardcoded in the movie.
The only way to "get rid of them" would be to re-encode using virtual dub filters te blur and fade out the subs. But this doesn't look that nice...
Greetz,
pSyChO dAdThe difference between genius and insanity is only measured by success ! -
If the movie is in widescreen and the subtitles are on the black bar at the bottom, you could create a blue bitmap with a black bar at the bottom (the same height or lower as the one in the movie) and import this and the movie into Adobe Premiere, then use chroma-keying to merge the two. (see adobe help for this, as I can't remember how to do it off hand). Then export the movie to a new file.
Or, given that you have black borders containing the subtitles couldn't you use Avisynth to crop it and the add the borders again? Should be no sign of subtitles then.
I have no experience in this. Just guessing.
/C -
The Blind leading the Blind.
Assuming embedded subs in a DivX (you didn't say anything about an external sub file) you have 2 choises.
If the subs are in the movie area, your hosed. They can be removed but not by you.
If they are in the bottom gutter area (black bars) you can remove them easily. In AVISynth or VDub you simply crop them out with one filter then re-pad with black the same area. You have to re-pad to maintain aspect ratio.
The trick is to do it without re-encodingTo Be, Or, Not To Be, That, Is The Gazorgan Plan
Converting MKV (Get rid of subtitles)
By kpat99 in forum Video ConversionReplies: 3Last Post: 4th Feb 2012, 08:50 -
How do I strip and get rid of Audio Streams and Subtitles in MKV x264 files
By whachano in forum Video ConversionReplies: 1Last Post: 8th Aug 2010, 00:44 -
Need help getting RID of subtitles in wmv (Windows Media Encoder)
By BooBerry in forum Video ConversionReplies: 4Last Post: 6th Feb 2010, 09:58 -
Getting Rid of PC Heat
By adalect in forum ComputerReplies: 29Last Post: 4th Jun 2009, 03:05 -
Getting Rid of Subtitles
By macbuz in forum MacReplies: 4Last Post: 16th Jan 2009, 19:09
