Hope this may be of value to someone.
I've been using an ADVC-100 and Scenalyzer for capturing video (satellite, VHS, laserdisc, etc.) for some time now--really works great.
Just learned (looked at the capture options, DUH!) that Scenalyzer has an option for capturing audio only. For those of you (old guys like me) who also has a large collection of vinyl/cassettes, it has one pretty neat feature--file splitting while you capture. I've always just captured the entire tape/record and then afterwards did the file splitting manually--the automatic ones, e.g. in Easy CD Creator, don't work very well. However, for some music (especially soft, low amplitude stuff), manual file-splitting can be extremely time-consuming. In fact, at one time, I searched for audio recording software on ZD-net that had such a "manual" track splitting capability during capture. No luck.
I'm not sure how the quality of the audio conversion in the ADVC-100 compares with sound cards, although I suspect it's pretty comparable, and perhaps a lot better in some instances (e.g. if you use your onboard sound chip). If anyone has any info, it would be appreciated. Anyway, hope this little tidbit may be of use to someone.
wwaag
Results 1 to 1 of 1
avi to dvd after scenalyzer capture
By robroth in forum Authoring (DVD)Replies: 7Last Post: 9th Jan 2012, 18:23 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 02:23 -
How should I capture my hi 8 videos with my Canopus ADVC 100 and TRV460
By eichelman in forum Capturing and VCRReplies: 4Last Post: 9th Dec 2009, 14:21 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 09:15 -
At wits end - Capturing with ADVC-100 and audio levels are extremely low
By Towncrier in forum Capturing and VCRReplies: 13Last Post: 18th Sep 2007, 19:04
