i have been trying all day to rip harry potter and the chamber of secrets with dvd shrink dvdxcopy and dvd decrpyt and i get to 50% and get an error message i just wanted to know if this was a common problem or if it is just possibly my discany help will be greatly appreciated this is driving me crazy.
p4 2.4 ghz
asus p4s8x mb sis 648 chipset
ati aiw 7500 video card
256m memory
80 gig ibm hdd
sony dvd rom
sony dru-500ax
Probably just your disk. I got it no problem with DVD decrypter and DVD2one.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
same here, I went: Smartripper->DVD2One->Nero
no problems. you didn't run out of space did you? can sneak up on you when ripping dvd-9s
Andy -
as racer-x said, it is almost certainly the "disk." Try to clean it with a cd/dvd cleaning solution. People ask this type of question very often and it has nothing to do with a particular movie, but rather, an issue with that particular disk being scratched or damaged. Most of the time, a cleaning solution will allow the disk to be fully ripped. Sometimes the scratch is so bad that nothing will work.
With a movie like "Chamber of Secrets" you have more of a chance of an error ripping the "main movie" because there is only 1 PGC on that disk, which is like 7 GB's, so if you have a scratch, the percentages are heavily in favor of the scratch affecting the main movie. -
I would say almost def the disc, i managed to rip it fine.
you could also try ripping it in your dru500. I just had the exact same problem with band of brothers and I thought it was the disc which it usually is. but then I got the same disc from a friend and it froze at the same point 52%. So I threw it in my dru500 and it ripped fine.
Harry Potter 6
By Drerunsit in forum Newbie / General discussionsReplies: 13Last Post: 17th Jun 2011, 12:23 -
Can't Rip Harry Potter Movies
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 16th Dec 2010, 06:06 -
I keep thinking this can't be right - 7gb for 1080p? Harry Potter movies
By AndyD in forum Blu-ray RippingReplies: 7Last Post: 17th Oct 2010, 08:45 -
Problem with Layer 1 & Harry Potter
By Jeptha in forum DVD RippingReplies: 0Last Post: 1st Sep 2010, 22:04 -
Download the Latest Harry Potter Movie: Legally!
By dvd3500 in forum Latest Video NewsReplies: 14Last Post: 26th Oct 2007, 12:53
