I have successfully used DVD2ONE OSX 3 times now without a hitch. I am trying to do Almost Famous and I can't get DVD2ONE to do it correctly. I have used DVDBackup to capture the movie. It works fine, I checked the captured files with DVD Player. Then I tried to use DVD2ONe to shrink them down so they will fit on one DVD and instead of creating a Video_TS folder with a bunch of files (as usual) it creates a Video_Ts folder with:
VTS_01_1.VOB
VTS_01_2.VOB
VTS_01_3.VOB
that's it. nothing else in the folder. total file size is like 2.35 GB. I selected the video with 31 chapters in the menu, and selected the 6ch sound....the same way i did the last two movies. so why is DVD2ONE just creating 3 files (relatively small)? It doesn't show any errors and takes the usual 30 minutes or so for the encoding. I tried reripping the DVD and using DVD2ONe again and got the same 3 files every time. What gives??
Results 1 to 1 of 1
3D movie 50GB BD-RE Dual Layer - but will it work ?
By testing1234 in forum DVD & Blu-ray WritersReplies: 14Last Post: 3rd Dec 2011, 19:21 -
Movie Rip i am now trying to get to work on xbox 360. I Love Help !!
By Cornholio77 in forum Video ConversionReplies: 7Last Post: 25th May 2011, 14:34 -
Can't get subs to work with M2TS movie
By seaofsorrow in forum SubtitleReplies: 0Last Post: 20th Mar 2010, 21:13 -
problem getting vga to work with hdtv
By GetYourShineBox in forum Newbie / General discussionsReplies: 16Last Post: 26th Feb 2010, 16:42 -
Why won't my VTS_01 file work on windows movie maker?
By LITEONDVD in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2007, 10:13
