Hi all,
I have Win XP with amd 2700 processor. Using VDUB ver 1.5.2.;
While attemtping to remove bad frames from an avi the program just crashes.
The avi is xvid compressed with ac3 audio. I have both codecs installed.
I have no issues locating the bad frames but when I try and move around them to set an endpoint the program will crash.
I tried with other versions and played with settings choosing no audio and direct stream copy rather than full processing. Nothing has helped.
The only other codecs I have are mpeg2 and divx(alpha+latest) just to play the files.
When it crashes VDUB addresses the problem to be associated with xvid codec. I have the codec installed from this site and cant open the file with vdub if the codec is not installed.
Any help would be greatly appreciated.
still tackling this one. Have not received responses here or at virtualdub forum. Can anyone please help?
Splitting/cutting/joining MP4 accurately...
By The.King in forum EditingReplies: 2Last Post: 2nd Nov 2011, 12:35 -
need help cutting and joining avi files in virtualdub
By granturissimus in forum EditingReplies: 3Last Post: 31st Jan 2011, 02:53 -
Hopefully an easy question about cutting and joining video with Virtualdub
By crumbworks in forum EditingReplies: 4Last Post: 18th Oct 2010, 14:21 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
WMV cutting-joining-playback problems
By Cusem in forum EditingReplies: 2Last Post: 7th Dec 2007, 03:48
