Hey folks,
Got a quick question. Seeing as I have only 74 min. blank CD-R's (for now) I am finding it highly annoying when I have a standard 2 hr. movie and the second part is just a tad-long and won't fit on the disk. I end up having to decrease the Video bitrate to make it fit, which compromises the fluidity of how the SVCD plays. Question is this: How can I set the bitrate specifically to the rate I want (From what I get from the bitrate calculator) without having TMPEGEnc always set it back to the default of 1600 kpbs...this is annoying me.
His Iceness
For using CBR? Just put in your CBR, then click on where it says bitrate, and it will pull up a little drop-down box that has Lock and unlock as choices, and choose "lock". Then save the settings as "whatever.mcf" and load that when you want to make an SVCD.
Or use VBR which is better for this type of thing anyway.
Yeah, 2-pass would give you much better results, but take twice the time. So it's a trade-off; quality Vs. time spent... :/
Have video container CBR or VBR ?
By n33 in forum Newbie / General discussionsReplies: 9Last Post: 14th Oct 2011, 06:03 -
Freemake Video Converter: How To Ensure CBR Audio?
By Tom Saurus in forum Video ConversionReplies: 1Last Post: 21st Aug 2011, 15:41 -
How to convert .CBR video file to WMV or AVI?
By microline2009 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jan 2009, 03:05 -
Optimal Hypercam 2 audio and video settings to record video?
By majax79 in forum Newbie / General discussionsReplies: 2Last Post: 27th Mar 2008, 11:46 -
Convert divx vbr to cbr audio - video freezes (possible reason & soluti
By lingyi in forum AudioReplies: 0Last Post: 4th Oct 2007, 16:51
