i take say 800mb file and split it in half say 400mb then i take it to tmpg to make a svcd and makes it over a gig. why is that.
The size of the output file is not dependant on the size of the input file. You can take a 5gig file and shrink it to 500MB. Conversely you can take a 500MB file and enlarge it to 5gigs. What determines the size of your output file is the bitrate at which you encode. A higher bitrate means a larger file.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
Lipsync-problem with copy of authored DVD (TMPG-related)
By fedet123 in forum Authoring (DVD)Replies: 2Last Post: 10th Oct 2009, 19:01 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39
