I use Tmpgenc to convert an Xvid to SVCD, but the result is not good (image are ok and the audio too, but image flicks). I tried almost everyting. The conversion from Divx to SVCD is always OK and don't give me any problem. Codec problem? Thanks.
Try using the program DVD2SVD using CCE as your encoder. I always use this and it never fails me. Make sure you get version 1.1 build 1
Hope this helps -
Download the 4cc changer, and change the XviD CC's to both say divx. This fixes a lot of problems with having an old codec or FFDShow problems.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
Divx/Xvid problem in Virtualdub (not mod)
By leeqk in forum Newbie / General discussionsReplies: 14Last Post: 11th Apr 2010, 01:18 -
AVI.net a confusing problem : using DivX instead of XVID
By Alterego in forum DVD RippingReplies: 5Last Post: 17th Jun 2009, 12:39 -
Xvid and Divx playback problem on TV set
By herbapou in forum Media Center PC / MediaCentersReplies: 3Last Post: 7th Sep 2008, 12:17 -
Vob to Xvid in autoGK or Divx Converter problem
By arcangel14563 in forum DVD RippingReplies: 1Last Post: 19th Nov 2007, 17:11 -
Problem with Divx/Xvid with Winamp and Virtualdub
By mekuka_pinasem in forum Software PlayingReplies: 5Last Post: 1st Aug 2007, 11:41
