i seprated audio using virtual dub from a divx file to avoid the sync problem after the speration i found out that the wave file the audio fil is about 1:18:09 long and the video is 1:21:29
the original download movie file also has big audio sync problem
what can i do now
can anyone plze explain coz iam newbie
I don't know if you have solved the problem, but here is a suggestion.
Load the AVI file into VirtualDUB (use a new version, such as 1.5.1 to find the filters I suggest).
Go to the audio menu and select Full Processing Mode. In the same menu, check the option "Use Advanced Filtering".
Then, in the same menu, go to Filters. The filters form will load.
Click Add and double click the "Stretch" filter. Then click on close.
Double click on the Stretch filter box that is added in the form. A dialog with the Stretch ratio is shown.
Calculate the stretch ratio you need, by converting the audio and video lengths into seconds (e.g. 1.18.09 is 3600 + 18x60 + 09 sec). Divide the video length by the audio length and enter the result with as many decimal digits as possible.
This will stretch the audio so that it becomes as long as the video.The more I learn, the more I come to realize how little it is I know.
Converting a 480x720 2:3 short to a 1280x720 16:9 HD short.
By Cyrax9 in forum MacReplies: 2Last Post: 14th Feb 2011, 17:40 -
short play and long play
By feebee46 in forum Newbie / General discussionsReplies: 2Last Post: 16th May 2010, 11:57 -
Converting long play to short play
By NiteCrala in forum Newbie / General discussionsReplies: 1Last Post: 28th Jan 2010, 09:46 -
Short Tape?
By DeederMc in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th May 2008, 01:55
