Does anyone know where I can get the Sony DRU-510?
I recently ordered from a web site a drive that was listed as the Sony DRU-510. I just received it today and the drive does not say Sony on the front but on top it says Sony DW-U10A. I was puzzled but did notice it has a recent manufacturer date (April 21, 2003) and I have never received something that new. I then researched on the net and found out that the Sony DW-U10A is a DRU500, not a DRU510. Is that correct?
As well, if I wait for the DRU510 and return this drive what do I gain? For one I get 4X DVD+RW. This would be important to me since I use DVD+RW for backup purposes. I see I also go from 8x to 12x DVD Read speed which isn't a big deal since I have a separate DVD-ROM that's 16x. Is there any other difference besides these two?
Also, if I do choose to just want the DRU500 and not the 510 will it be any problem with me just having the DW-U10A. I have heard the DW-U10A has different firmware than the DRU500 and even that it's a way to make it a DRU500. My concern is that this slight difference will cause problems (such as future incompatibility with newer firmware, etc).
DW-U10A is equivalent to that of the DRU-500A not DRU-510A which is not on the market yet. Even though both of the drives are physically identical the firmware is different. DRU-500A has firmware updates while it is next to impossible to get a firmware update for DW-U10A unless it is a hack version which too is hard to find and unrealiable to use. The only difference with DRU-510A is 4x DVD+RW write while the other specs remains the same.
Sony DRU-810A Hook-Up Issue
By elwood55 in forum DVD & Blu-ray WritersReplies: 3Last Post: 20th Jul 2011, 17:46 -
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 15:10 -
Sony RDR HX 510 and DVP NS 305
By SearchQuality in forum MediaReplies: 10Last Post: 16th Nov 2007, 11:41 -
Sony DRU-810A question...
By bamabluebird in forum DVD & Blu-ray WritersReplies: 4Last Post: 10th Jul 2007, 11:21 -
Sony DVD RW DRU-830A
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41
