Hi All,
I wish to capture my Sony TRV-130 DV camcoder films to guest room DVD (Not PC DVD):
I connected the camcoder to the firewire card and downloaded Microsoft Movie Maker. Starting capturing and got a 940MB file, using "Video for local playback" type, 2.1 Mbps.
Now, I wish to burn it on DVD. Is it the right fomat? Does it use MPEG2 format? As much as you know, there are a lot of parameters while you shrink a file: Stream variable, Resolution (I used 640*480 - Is it OK?), Frame A, B or both etc. Does the DVD can play all of the parameters of MPEG2 or there is a standard?
Thanks,
Uriel
When I've used Movie Maker to transfer the DV content from my Sony D8 camcorder, I've selected the DV-AVI option. This puts it into AVI format, which can then be edited by other software and processed into MPEG-2 video and WAV/MPEG-1/AC-3 audio format.
Check out the helps on the forum regarding the creation of 'compliant' DVDs using AVI source that can be played on set-top DVD players. -
Your DV burner should come with the necessary software. If you prefer, you can capture using Windows Movie Maker in DV avi and then convert to mpeg-2 with TMPGenc. You can then import the file into your DVD authoring program.
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 11:42 -
ADS DVD Xpress capture issue 8MM to DVD
By xxnonamexx in forum Capturing and VCRReplies: 1Last Post: 13th Dec 2007, 21:20 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 18:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 19:42
