are these dvd-r any good
Ritek Silver 4.7gb 1 Speed DVD-R
can i record these dvd-r at 2 speed with my pioneer A05
Results 1 to 11 of 11
nuff respect
I just switch to these Riteck discs!!
I had a bad experience with Princo discs so I tried Riteck.
I am very happy with them, I have burned about 30 so far and not one coaster! Its what I will be buying from now on.
Not sure about the 2x burning, I burn at 1x.
I have a Pioneer DVR-105/A05
Check a compatability chart when/if you order, it might help you with your 2x question. Or with any luck someone else on this forum can help us!!
Hope it helps. -
I'm like Evil Twin. After bad Princo, I got those disk (I got a 100 spindle with my friend (50/50))
They record at 2X on my LG drive with no problem. My friend record them at 2X with a Pioneer A05, but I think he got an hacked firmware.. anyway incredible disk so far.. go ahead and buy them ! -
I'm a fan. Also a convert from Princo's. I'm a little perturbed that the price keeps going up, but I like burning them at 2x on my 105 with the hacked firmware. No coasters!!!
Riteks have been very good with me as well.
I have burned almost all using the 2X4ALL firmare hack.All I've got in this world is my balls and my word.....
and I don't break them for no one! -
I believe that these Ritek silvers are the G03's that everyone loves. These disks are really good. They are inexpensive (notice I didn't say CHEAP) and good quality. I've burned 200 of these disks and have never had a problem with any of them. The Apple/Verbatim/Pioneer-only people are really missing out on the excellent quality of these disks.
I burned almost 500 of them on an AO4 can't get one of them to burn on my Vivastar which to me is strange since my Vivastar burns good under 4GB on all the cheapest of discs and won't even recognize a ritek
I too have had great success with the Ritek G03's...
They are not the cheapest, but they work for me and are cheaper than the "brand name" disks...Use what works for you... -
I am using Riteks G03 (silver top/Purple bottom) with the A05. I am burning at 2x with the custom firmware (1.30) made by >NIL: and Gradius's version 1.30 w/RPC1+2x4all. You can get it from this site: http://forum.firmware-flash.com/viewforum.php?f=2&sid=0f691286b62c84c4ac058f424f7afe5f
Ritek are superb.Originally Posted by tonyburns
I read they have approx. 51% market share and quite rightly so.
Are you in the UK?
If so, where did you/do you plan to get them from?
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
minted dvd with ding in silver part
By spiritgumm in forum MediaReplies: 6Last Post: 20th Jun 2011, 23:13 -
dvd burner with silver lacquer dvds
By hardy in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2010, 11:11 -
Where can I get Silver DVD-Rs?
By Motiondrops in forum DVD RippingReplies: 4Last Post: 19th Jul 2008, 11:22 -
looking for silver hub printable DVD media
By PharmBoy in forum MediaReplies: 6Last Post: 30th May 2008, 05:31 -
Unzipping a 4.7GB File Speed
By mn072065 in forum ComputerReplies: 4Last Post: 13th Jul 2007, 12:20
