  1. I created oval type buttons in DVD Menu and exported as .psd file. I then imported it into Maestro and set it as the sub picture in my settings. However I notice that the hot spots are not trasfered and that you have to create the hotspots in Maestro. The problem is that I can only create a rectangle type hot spot over my oval button. This causes the mapping of color to not stretch over the entire picture. What do I do? Am I doing this correct or am I missing something Big Time!!!!!!!!
  2. Buttons are always rectangles - you need to set up your subpicture mask so that this is not a problem.
    For instance - Oval picture, oval subpicture in red, then square button.
    The highlighting of the square button will only affect the oval subpicture.
