Hey,
Come on and help me!
I have burnt my mp3 using nero, but strange thing happens that after compilation nero increased my mp3s considerably!!! so that i can burn only 18-20 mp3s on a CD-R of capacity 700 MB. I wonder while nero increased the size of the original mp3 instead of decreasing it. Somehow i got a recorded CD-R from my friends and to my extreme surprise i found that it contains 200 mp3 songs.
Pls. tell me also what technique i could implement so that i wouldn't waste too much CD-Rs.
Ah! I WANT 200 MP3s IN A SINGLE CD-R
Thank you.
It's me,
Strain.
Are you trying to record as an audio disk? YOu don't want to do that - that will convert the mp3s back to wav, which is large.
Record a data disk - then you can record 700 MB of mp3 files. However, be aware that you can only play this CD-R in a computer, or an MP3 player that supports CD-R - it won't play in a standard audio player. -
it should be possible for you to get around 200 to 240 mp3s on a 80 minute cd,if the bitrate of each song is 128 kbps or 96kbps and lasting 3 minutes or less.
Burn the disk as Data, not Audio. An Audio disk like what you buy in a store, and is limited to (approximately) 80 minues of sound. A data disk is limited to 700 MB of MP3's.
Nero is converting the mp3's for you to make an audio Cd (that you selected). Common mistake, no big deal.To Be, Or, Not To Be, That, Is The Gazorgan Plan
choice: burn to single BD, or multiple movies in 264?
By jlm86 in forum Blu-ray RippingReplies: 15Last Post: 20th Feb 2011, 21:14 -
Possible to burn a single 8gb file on a DL disc???
By moggsy in forum DVD & Blu-ray WritersReplies: 22Last Post: 11th Jan 2011, 21:09 -
How fix mp3 with audio comming out of a single speaker ?
By hiavi in forum AudioReplies: 2Last Post: 17th Sep 2009, 23:28 -
Combining a single picture with an mp3 to create video file
By mark1111 in forum Newbie / General discussionsReplies: 2Last Post: 7th May 2009, 05:13 -
Is there such a program which can split up this 1 .mp3 into single songs
By natty in forum Newbie / General discussionsReplies: 6Last Post: 8th Apr 2009, 22:35
Strain.
