    Apr 2003
    Uk England
    Hello, i searched the forums for an hour now and still cant find a noob friendly guide to convert vcd to svcd, can someone plz point me in the right direction!?
    copy the vcd .dat to mpg to your hd with isobuster or vcdgear www.dvdrhelp.com/convert#other
    and convert to svcd with tmpgenc
    www.dvdrhelp.com/tmpgencsvcd
    and burn with vcdeasy
    www.dvdrhelp.com/vcdeasyhowto
    BUT you will lose a lot of the video quality, Garbage in Garbage out. And resizing up the image resolution is never good(352x240 to 480x480). So I don't see why any would like to do it...except that your dvd ONLY support svcds or something...
    Apr 2003
    Uk England
    Cheers Baldrik, Well i am new to the world of ripping,burning etc but i want to convert a VCD to either SVCD or DVD and a SVCD to DVD, basically to ressolve stand-alone player issues and also to see if it can improve quality on the SVCD to DVD.
    I appreciate the info , thanks.
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Garbage in Garbage
    ArA1337: you wont improve quality reencoding SVCD2 -> DVD. I'd try making a DVD-SVCD (SVCD on a DVD) first to see if thats compatible with your system. If not reencode to proper DVD: Will be compatible, will lose a little quality & will take ages!
    https://www.videohelp.com/guides?formatconversionselect=SVCD+to+DVD
