Hi
Anyone found out how to use the 2 pass vbr conversion using the new Divx4 codec with TMPGenc.
Have very succcesfully used TMPGenc, using the d2v and wav files generated by dvd2avi, and simply using the 1 pass option offered by the divx4 codec compressor and mpeg-3 audio, to generate a divx avi.
Cant work out though how to use the 2pass vbr option ?
Anybody done this --- any ideas??
thanks in advance
PS: I know there are probably other methods but I like TMPGenc![]()
you have to use "2-pass, first pass" at first with the settings you want and then encode the movie. after this finished you must encode a second time but now with "2-pass, second pass" with the same settings.
Olddrunkard
Thanks for your help here....you are absolutely right...just found out myself by carefully reading the help files that came with DivX4, which I should have done in the 1st place !!
Truman........guess you may have been confused a little in the posting. TMPGenc is only being used as the "vehicle", and I am not trying to use its own 2passVBR encoding. The Divx4 codec provides its own 2pass system.
Nidoran.......how do you do this, have you done this ?
PS : tried a quick 2 pass sample and it works very well giving excellent results.....a bit of fine tuning now !!
regards
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 15:59 -
VBR (Variable Bitrate) WMV file to avi conversion process problem...
By Atakanbasturk in forum Newbie / General discussionsReplies: 10Last Post: 31st Oct 2009, 16:44 -
[SOLVED] TMPGEnc DVD Author doesn't like VBR??
By Taeran in forum Authoring (DVD)Replies: 5Last Post: 19th Sep 2008, 18:11 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 11:16 -
VBR encoding problems with TMPGEnc 4XP
By maccool111 in forum Video ConversionReplies: 2Last Post: 8th Jun 2007, 04:42
