Hi,I'm in australia
I just got Pinnacle PCTV to capture directly from areal.
I did the auto scan to get all the chanels but it seems it can't get all of the TV stations. Is this normal? the picture is so bad.
I installed the original driver from the cd.
I have checked on some posting about this card and some people suggested to install other drivers. which one is the best?
Dani
Hi,
Make sure you don't do the "fast" scan, and specify if you'ra on cable or antenna. If I do a "fast" scan, I just get 4 channels instead of the 34.Just because you aren't paranoid, doesn't mean they aren't out to get you! -
Thanks for the reply.
I'll make sure I don't do the "fast scan".
my next question is :
Do you get (kind of) pixelated picture when you view your TV (antenna)?
How do you get clear and good picture?
I tried to fine tune it but I had no luck so far.
Any help is appriciated.
A -
dunno, I don't have an antenna...
Picture is not pixelated.Just because you aren't paranoid, doesn't mean they aren't out to get you! -
If your resting your areal on your computer the issue is probly electrical interference. Especially if you have say, 2 computers back to back
hello again.
yes, I think your are right. electrical interference is the problem.
I tried to move(install) the card on different PCI slot but it seems it doesn't make any difference.
What should i do to get rid of the electrical interference?
Please help.
Software for Pinnacle PCTV usb2
By jodal in forum Media Center PC / MediaCentersReplies: 11Last Post: 28th Apr 2010, 06:32 -
pinnacle pctv 310i
By marc21782000 in forum Capturing and VCRReplies: 10Last Post: 4th Jan 2010, 03:30 -
What software for Pinnacle PCTV HD?
By tomreedtoon in forum Capturing and VCRReplies: 10Last Post: 9th May 2009, 07:14 -
Pinnacle Studio PCTV upgrade?
By visionman in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2009, 14:41 -
Pinnacle PCTV HD Ultimate Stick
By bigjimmpls in forum Capturing and VCRReplies: 19Last Post: 28th Dec 2007, 15:40
