Hi! after waisting a day of my time and many many CDR's i decided to quit with "VCD header trick" and it might not play with my dvd player nway so i found out that i can play XVCD on my dvd player.... and the quality REALLY improved greatly! compared to a VCD! vcd might be good if your original is a dvd movie but mine our home videos... nway... my question is SVCD da same quality as XVCD?
i set my bitrate at 3000!!! its suppose to be 2500 like it says but i decided to go higher and 3000 is max for me...
thanks all! tc!
Results 1 to 13 of 13
My cheapo Apex 1201 ($53 US) will play SVCD's at bitrates over 5000.
I make my xSVCDs with a min of 300, max of 3000, and an average to fit; 2 pass VBR with 192 mp2 audio, usually downmixed from the AC5.1 track. I typically make 2 disks up to 100 minutes, 3 disks up to 135 minutes and 4 disks over that. It depends on the movie, action flicks get a higher average and chick flicks get a lower.
On my 27 in TV, with only a Dolby Surround stereo, I can't really tell the difference between the xSVCD backup and the original DVD. One BIG difference is I don't have the 10 minutes of annoying Disney commercials I can't forward through!!!To Be, Or, Not To Be, That, Is The Gazorgan Plan -
XVCD doesn't say much, but if you've just raised the bit rate, SVCD will look better, at least at that bit rate, because of its higher resolution.
/Mats -
thanks guys for the reply's~! appreciate it!
"My cheapo Apex 1201 ($53 US) will play SVCD's at bitrates over 5000. "
WOW! nicee!!!! too bad my player cant play SVCD.... wow xvcd must be nice!!!....
hey do u guys know if burning at low speed like 4x increases da quality? i burned at fast speed 8x
Also, if i se it to 720x480 will it increase da quality? cuz i do da standard 352x240
hey mats... if u say xvcd isn't dat good... then is ther any other way for me to get better quality? like any other trick so that i can play SVCD? or maybe I can burn to DVD? any help to improve XVCD quality is greatly appreciated..
thanks guys!
thanks! tc! -
Since your player seems rather open minded when it comes to VCD, try creating an XVCD with SVCD resolution and bit rate (but keep it mpeg 1, and author as VCD) to see if your player still accepts it. If so, you've lost (almost) nothing, as picture quality wise, mpeg1 is not inferior to mpeg2 at the same res and bit rate. You can't do selectable subs and such fancy stuff, but...
Keep in mind tho, that your next DVD player may not be so friendly to your way out of specs VCD!
/Mats -
yo matt! thanks a lot! really great info! im excited now! can u please tell me wats is SVCD Resolution and bitrate? i'm bout to do XVCD ryt now... and i have
aspect ratio: 4:3 525 line (NTSC)
Frame rate: 29.97 fps
Bitrate: 3000 kbits/sec -
hi LanEvo7! thanks ill reaad more info bout cvd! but will this play on my dvd player? and most dvd players? wat do u think bout cvd matt?
If your player can't do SVCD, I'd think that CVD is out ouf the picture (no pun intended) too, as it's basically a SVCD with res 352*576/480 (PAL/NTSC) instead of 480*576/480
My suggestion was - do a XVCD exactly like you do now, but try with the SVCD res of 480*576/480. If it works, but is too "blocky", try CVD res too. Hope you use CD-RW!
/Mats -
thanks matt! that helps! nop, dont havd CDRW's but i'm gona get one! for sure! its a good idea! for experimenting... i hate waisting 80min CDR...
CVDs are more compatible than SVCDs as it is Half-D1 resolution., which is a standard resolution for DVD.
hey matt i got an idea... i'll just see how it looks on my computer... cuz i dont have cdrw's ye.t..
lan, ive checked for my dvd player and it says it doesnt support it... but maybe it might work... ill test it when i get a cdrw heheeh... thanks! i sure do hope it wuld work though..
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 09:34 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 11:27
