This is going to sound like a really daft and simple question, but in what programs can I find the EXACT lenth of a video file? All the programs I try just show minutes and seconds like 12:52 or whatever, but I'm currently trying to stretch some audio to fit a video file to cure some sync problems so need an exact length down to the last milisecond. I can find out the time of the audio easily, just struggling to find a program that will tell me the video length...
Use virtualdub, open the video and click on the [End]-button at the bottom ( looks like this >| ) and then you will get the exact time to right like Frame 21501 ( 0:14:38:003 ).
Also tmpgenc, tools, merge and cut will show you seconds.
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 08:08 -
What are the exact requirements for a video to be AVCHD complaint ?
By ahmadka in forum Authoring (Blu-ray)Replies: 4Last Post: 1st Jun 2011, 19:24 -
NTSC/PAL but exact film length: How so?
By Anonymous5394 in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2010, 11:42 -
How to check the exact video bitrate in Kbit/s
By BassJunkie in forum MacReplies: 2Last Post: 15th Aug 2008, 11:31 -
How to find the exact parameters used to encode a video
By SoupNazi83 in forum Video ConversionReplies: 4Last Post: 18th Jul 2008, 19:10
