Hi folks!
I got an .avi film which has the format 512x400. Length 1:21:40. I use the greatest proggy on earth for encoding: DVD2SVCD.
1. I didn’t use any special settings for DVD2SVCD (beside bicubic resize). Does DVD2SVCD resize the movie without cropping something or does it cut some lines? Using Windows MP the picture is distorted but with my standalone it doesn’t seem so. With TMPEGEnc I figured out that the picture is distorted (I got cone heads) but now it seems OK, but I’m not sure.
Does it also work with 512x384, 704x544 and 400x304?
2. After transcoding I got two files. One is 800MB, the other 600MB. Why doesn’t DVD2SVCD use two times the whole 800MB as I told it to do? The settings are:
So I think it made one 50min CD and one 32min CD and not two 40 min CDs whitch must have greater bitrates. Am I right?
Here is an cut-out of the LOG-file:
- Restarting from: Video encoding
- 05.05.2003 20:42:20
- Free on drive D: 5023.23 mb
- Video Encoding using Cinema Craft
Executing Cinema Craft Encoder.
StreamSectors: 1667869728
AudioSectors: 118677384
VideoPAPO: 23997816
ScanOffsetBytes: 146158
SeqAligningBytes: 9289127
DVDBytes: 0
VideoEndHeader: 8
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 1.00
PureMPEGStream: 1515759234.93
Seconds: 4878.92
CalcMPEGStream: 1515759234.93
Frames: 121798
CDSize: 800.00
Number of CDs: 2
Cut point 795.00
Variable Settings:
Frames: 121798
Anti Noise Filter: Off
Passes: 3
Image Quality: 17
VAF file creation: On
Video Encoding Mode: Multipass VBR
Min. bitrate: 300
Max. bitrate: 2530
Avg. Bitrate: 2230
Aspect Ratio: 4:3 (No borders, encoded as 4:3)
---AVS Begin---
LoadPlugin("C:\PROGRA~1\Zubehoer\Video_CD\DVD2SVCD \MPEG2Dec\mpeg2dec.dll")
AVISource("E:\Filme\sonstige\GW\GINAWI~3.AVI",Fals e)
ConvertToYUY2()
BicubicResize(480,576,0.0,0.6)
ResampleAudio(44100)
----AVS End----
Closing program
CCE Max Speed: 1.000
Video Encoding finished.
Thanks a lot!
Diver
Welcome - to the real world
Diver,
Will try and answer all questions.
As far as I know it will not crop the image when resizing but I have never had an input of 512X400?? DVD2SVCD may not be able to do that ratio if it does not recognize it. The forums at doom9.org will be probably more help than here though if you get really stuck.
The reason you didn't get 2 800Mb files is because your bitrate is too low.
Keep your bitrate higher then you will get 2 800mb files. Put your avg. @ say 2600 - 3000 and max. @ 4000.
hope this helps somewhat.All I've got in this world is my balls and my word.....
and I don't break them for no one! -
Hi jnk76
Thanks, but:
DVD2SVCD has no problem with the size. But I don’t exactly know what it does with the picture. There also is the resizer. I must have a closer look to it.
Do you know some software which spreads the picture to fullscreen and crops it at the both sides? So I can “enlarge” the picture to lets say 19:9 and forget the left and the right side.
If I increase the bitrate it won’t be conform with the standard, am I right? And if I enter just some numbers the movie perhaps won’t fit on two CDs!?
So is there another tip?
DiverWelcome - to the real world -
Diver,
As far as I know DVD2SVCD will just stretch the picture....it will not crop it. TMPGnc should do that for you. As for bitrate.....I thing you had chosen 480X576 which will have a limit......If you are doing DVD then it can go up almost 10MB/s.All I've got in this world is my balls and my word.....
OK Thanks for the help.
So I have to make some further tests.
By
Longevity of CDs and DVDs? Are my old CDs starting to lose it?
By garybeck in forum DVD & Blu-ray RecordersReplies: 15Last Post: 25th Jan 2013, 13:38 -
In plasma TV "Number of pixels" and "Number of dots" it's not a same term?
By flash_os in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2011, 12:27 -
ffmpeg Number of stream maps must match number of output streams
By tmiller_15 in forum Blu-ray RippingReplies: 1Last Post: 13th Nov 2010, 06:20 -
aol number
By Mr anderson in forum ComputerReplies: 5Last Post: 10th Oct 2008, 06:39 -
need serial number
By besty01 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 24th Jan 2008, 07:29
