  1. ...for this encrypted file! At least that's what Smart Ripper (under VPC) had to say.
    I tried everything with this damn disk, DVD Backup 1.3, OSEX (File & Image mode), I even (uggh) booted into OS9 to try DVD Extractor but when I could get a file to my drive that old demon encrypted bit would pop up and DTOX wouldn't process the file. Out o sheer desperation I ran SmartRipper on the disk and sure enough it had quite a few encrypted blocks. No prob, SR will decrypt those blocks but them it came up with a "No Keys .. etc." stuff on one of the Vobs. What's up with that shit? Is there something else that is possible to try that I'm missing? I just HATE to admit defeat!
    Disk:Eastern European disk authored by a company named SPI (go figure)
    Title: Jay and Silent Bob Strike Back (at my computer)
    Format: PAL DVD-9
    Anybody else have this problem, or better yet, a solution?
  2. By the way, DVD backup couldn't couldn't find any keys for this vob either.
  3. Member Thargok's Avatar
    Nov 2001
    Play the DVD in Apple's DVD Player so you can set the region and then try it.
  4. Originally Posted by Thargok
    I wish!
    I tried it with DVD player open, I tried it with DVD player closed, I really wasted way too much time on a movie that I really don't need to back up anyway, I'm just worried that this same problem mightrear its ugly head on a DVD that is worth it. Thanks for the advice anyways. Anybody else?
  5. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    I don't think that DVD Player can be open for DVDBackup to work. I believe what he was saying was for you to run the disk in DVD Player, then close DVD Player, then run DVDBackup and see if that works.
