  1. When I try to use the tool "Multiplexer" in Videopack 5, whenever I load the audio stream (.mp2) the program gets stuck.
    I run this program under WinXP and I have installed the patch.
    Anyone familiar with this problem/has this problem?
    cheers
  2. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    It's been a while, but I think you need to rename audio file to .mpa.
    Worth a try anyway.
  3. Tried renaming it, didn't help
    Keeps not responding after I load the audio stream.
