i get the a blank screen i let it continue i burn it onto cd but when i take it to the dvd player it is still blank black screen
please help me i have had only one turn out for me done alot of d/l for nothing it seems unless i want to watch them on the computer which i would prefer not too
please i need help
yes i am just a stupid female who needs help :P
Results 1 to 10 of 10
Does your dvd player support vcd's do you get any error messages.
It seems like the encoding of the AVI is something TMPGEnc cannot decode. Try opening the AVI in VirtualDub. If it looks OK, then frame serve to TMPGEnc.
/Mats -
Originally Posted by hardcoreruss
Originally Posted by mats.hogberg
Then surely your computer can't handle de encoding used in the AVI. Use GSpot (see Tools) to see what codec's used in the AVI. Then install/update those codecs. If it's an XviD, ffdshow might be needed too.
Come to think of it - what is your source material?
/Mats -
i can then view them on my computer
i then open TMPGEnc load the file it encodes blank
never did this before
some files i get down will not work in TMPGEnc so i have to use
winmpg and convert them to all avi
then encode but lately when i do that all the movies are upside down
so i have to problems no
was told to get ffdshow and click on flip but it dont flip it
this gspot did something but i dont know what ?
this is so hard -
GSpot doesn't do anything - it just tells you the innards of the AVI, and if your computer can handle the particular AVI or not.
Since you d/l from KaZaA, there's no telling what quality you can expect, if it's OK at all. The upside down problem is due to some (conflicting) settings in the codec/s used when decoding it.
/Mats -
When you load the avi in gspot it will tell you what codecs are needed to decompress the film. If you don't have the proper ones installed it will tell so. You will then have to download whatever codecs are needed to encode the film. If you downloaded the film from Kazaa chances are it is an xvid film (uses an xvid codec).
lijoda in Tmpgenc goto environment and under options select Vfapi plugin
Check that you have the Direct Show multimedia at a priority of 4.
I would advise checking you have the Divx 3, 4 and 5 codecs installed and also install the direct show filters found here
http://www.doom9.org/Soft21/Filters/ffdshow-20021213.exe
Tmpgenc wont work properly on Divx without these filters.
If you dont have the Divx codecs they can been found here http://www.divx-digest.com/software/divxcodec.html
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
