I've had my capturing with virtualdub down to a science for a while, capturing a whole show and dropping zero or maybe one frame. Now all of the sudden it's dropping 10 in 3 minutes, and I haven't changed a thing.
What's happening to my setup?
Some possibilities.
Are you capping to the same HD?
Maybe it's time for a defrag.
You could have changed a setting without remembering such as selecting RGB24 instead of yuy2 (which is usually faster) or an option in your video or audio compression codec etc...
Are the 10 frames all at once or spaced out over the cap? All at once would indicate an interrupt or a brief bottleneck somewhere. This can occur if you are running something else at the same time (even your virus checker or your firewall) can sometimes wake up at the wrong time and draw on the cpu or hd.There's not much to do but then I can't do much anyway. -
I defragged and it's working fine again. Thanks. I captured 40+ minutes with 7 frames dropped.
Dropping frames on New PC
By beammeup in forum Capturing and VCRReplies: 9Last Post: 16th Apr 2012, 11:36 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 21:15 -
HDVSplit dropping frames
By Boadicea7 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2009, 08:47 -
Dropping frames while converting to .dv
By Huntr777 in forum MacReplies: 1Last Post: 10th Jun 2009, 16:19 -
New Computer Dropping Frames
By bthig in forum Capturing and VCRReplies: 20Last Post: 14th Jul 2008, 15:06
