I burned a DVD-R using Nero with vob files created by TMPGenc Authoring and it burned well. I put it in my Pioneer DV-440 and it played the video, but no sound! When I went to the menu to select an audio track it said MPEG 2ch was the audio...which is what I had TMPGenc set it to...so I took the disc out and put it in my computer on PowerDVD and it played the sound fine...i then put it in my GO Video DVD/VHS player and sound works fine...why can my reasonably recent DVD player read this? I intend to convert VHS for friends and having compatibility issues like this is unacceptable...do I just have to leave it at PCM and take up more room?
Derek
The DVD standard only supports PCM (uncompressed audio = wav) or AC3 audio. MPEG2 layer I (mp2) audio is not supported by the standard, and while the vast majority of DVD players will play it anyway some will not.
You should re-author your DVD with either PCM or AC3 audio:
http://www.doom9.org/audio-guides.htm -
All DVDs read ac3, only some read mpeg audio.
AC3 Machine (free) can encode to ac3 for you.
AC3 uses the same compression size as mpeg audio.
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 09:52 -
Here is how to create PS3 Compatible Files with 5.1 Audio
By pogues in forum MacReplies: 1Last Post: 5th Jan 2009, 01:30 -
Vista compatible mpeg joiner where 2 clips have diff dimensions?
By wetcamelfood in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2009, 14:14 -
Compatible Burner for Womble's "MPEG Video Wizard DVD"?
By cyberboy in forum Authoring (DVD)Replies: 3Last Post: 4th Jul 2008, 23:25 -
What is the most compatible audio for a DVD?!?!?!
By guitarparth in forum Newbie / General discussionsReplies: 7Last Post: 15th Nov 2007, 19:45
