Peace to all,
1. What is the best fps (frame rate per second) for VCD?
I've tried to put the standard motion-picture rate which is 24 fps, but the movie seems running faster than in its swf format.
2. What is the best dimension for my VCD when we set in Flash?
Thank you
A:
1.29.97fps(NTSC)or 25fps(PAL)TV;30fps PC
2.if the VCD is to be viewed on TV then 352x240(288 PAL),if it's to be viewed on PC then 4:3(320x240,640x480,800x600) would look better and it is a XVCD.
https://www.videohelp.com/vcd
streaming : frame rate & compression
By mathmax in forum Video Streaming DownloadingReplies: 2Last Post: 20th Apr 2011, 17:27 -
Frame Rate Conversion
By roberto188 in forum Video ConversionReplies: 17Last Post: 5th Mar 2011, 11:11 -
720p frame rate
By maggas in forum DVB / IPTVReplies: 6Last Post: 24th Jan 2009, 06:27 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 11:15
