  1. I was created/capture dfrom camcoder using true blue action hardware & software. its about 2 hours MPEG file. But the audio & video is not concurrently the audio is early than video. Why? what should I do??
    thanks
    Jan 2001
    Vancouver/Portland
    its called Audio Desync
    perhaps you should check ON the option found in "Timing" submenu in VirtualDub...
    otherwise, if that already checked ON, then i dunno...
